  2. Things you need to know about the new ‘Conversations’ PM system:
Ikea Kallax Shelving - Help with weight considerations
Discussion in 'audio' started by hockman, Aug 17, 2017.
  1. hockman
    hockman pfm Member
    Because of my ever expanding record collection piling up on the floor, I am thinking of getting a couple of Kallax shelves. I am looking at the double 4-shelf units to be installed on their side, e.g.:
    The problem is Ikea states that the max. load per shelf is 13kg. According to my estimates, each shelf is able to contain approximately 90 or so records depending on how tightly you pack them. Thus each shelf would easily weigh about 25 kg, way in excess of the weight limit.
    So how do people manage to fill up their Kallax units with records, I wonder? The Ikea website pics even show records on the Kallax along with the fashionable turntable.
    My alternative is to have the shelves custom-built which would likely be much more expensive but not that much better aesthetics-wise.
  2. zippy
    zippy pfm Member
    I think you'd be OK if you used some angle brackets under the shelves to reinforce them (I've done this on my hifi cabinet) OR even better, squares of white melamine the exact size of the cupboard under the shelves, and fixed to the sides so the support is then underneath (if you know what I mean - it's almost impossible to accurately describe it !)
    The problem is usually that the shelves are cross-pieces which rely on a couple of dowels or similar into the side pieces for their support, and that's not the strongest way to support the shelves.
    Having said that, I suspect IKEA are covering themselves by quoting 13 Kg - they'll probably hold a lot more
  3. Bob McC
    My Kallax (actually it's predecessor) is 4 X 4, stuffed to the gills with vinyl in every section, has stood for 5 years, is still absolutely solid.
    No need for reinforcement.
    The only change I added was thin strips at the back of each opening to keep the albums in and slightly forward.
    However the illustration is orientated wrongly.
    It is essential that the unbroken shelf goes horizontally.
    Mr Cat likes this.
  4. Alfaholic
    Alfaholic Member
  5. Whaleblue
    Whaleblue The Mighty Deoxitiser
    The predecessor to Kallax used rather thicker materials if I remember correctly.
  6. Pinky
    Pinky In suspense, not compressed
    I've got a Kallax 4x4 and a couple of it's predecessor Expedit, also 4x4's. No problems with full shelves of records. Although the Kallax has slightly thinner panels they are supposed to be just as strong if not stronger than Expedit (according to IKEA blurb I saw at the time).
    Also, does an individual shelf full of records really weigh 25kg? When I'm home later I'll take a shelfful out and weigh them!
  7. GaryT
    GaryT pfm Member
    I'm using a 4x4 with a 1x2 sitting on top. The 4x4 is attached to the wall using the supplied brackets, and I've had no problems (been up 3 years now). As long as you have the long shelf running horizontally there should be no issue.
    [​IMG]Kallax by gthompson60, on Flickr
  8. Dougie2404
    Dougie2404 pfm Member
    Like Bob mine has around 80 to a section, no problems, also a 4x4 and using 9 sections at the moment.
  9. guey
    guey pfm Member
    As people have said, they're fine if oriented correctly - that illustration isn't.
    If you want the top to be at that height, you'd have to use double the number of the 2x2 units.
  10. Nero
    Nero It's unlikely
    It's a good idea to glue it together, and orientate it correctly :)
    Rick_F, Hempknight and Mr Cat like this.
  11. hockman
    hockman pfm Member
    I was wondering when that photo was going to show up. :) Yes I am trying to avoid that, hence my question.
  12. stevec67
    stevec67 pfm Member
    The failure mode for these is that they parallelogram (shear failure, structural engineers) and this is more likely when they are 4 wide 2 high than the vertical option. The fix is to screw them to a wall or stiffen the back with some hardboard or other bracing. Yes,hardboard. Looks useless, is useless under bending, but fantastic when properly used.
  13. Bob McC
    If you note though in the picture the long shelves were vertical.
    That is a recipe for disaster.
    Put them horizontally.
  14. mikemusic
    mikemusic pfm Member
    First I saw the records - ouch
    Then the rack
    What about the turntable !!
    One unhappy bunny there
  15. Pete MB&D
    The rack has racked!
    Its the wrong way round but the failure was caused by it racking i.e. tilting over sideways, if it was fixed to the wall or had some diagonal strapping it would not have failed.
    If you undo the bottom of a cardboard box you can fold it flat.
    Pete
  16. scolarest
    scolarest pfm Member
    Shirley the quick way to stop prevent the parallelogram (shear failure) I found was to insert the Kallax cupboard door modules.
    Last time I looked £8 a shot but they kept the front nice and tidy and also stopped the cats from sharpening their claws on the record sleeves.
  17. Pinky
    Have just checked the quantity and weight of one typical section in my Kallax 4x4 unit.
    It's holding 88 records which weigh in at 23.3kg. Heavier than I realised!
    The records are a typical mixture of standard albums, gatefolds and 12" singles. All are in plastic outer sleeves. There is room to fit two or three more in if I wanted to squeeze them in.
    Hope this helps with your deliberations!
  18. Pete MB&D
    I think fixing to a wall would be better.
    Pete
  19. Tony L
    Tony L Administrator
    If oriented correctly Kallax will easily take the weight - the pfm record shop relies on them! The thing I'm not certain of is if the 2x4 on its side is oriented correctly, I suspect it may not be. Long shelves need to be horizontal, short dividers vertical, no exceptions.
  20. k90tour
    k90tour pfm Member
    A year on and so far so good. Even with all that heavy Wagner onboard
