£500 streaming system
Discussion in 'audio' started by Gerard124, Sep 10, 2014.
  1. Gerard124
    Gerard124 pfm Member
    Been asked by a family member to help with a lounge based streaming system, something more than an ipod dock.
    I’m thinking suggesting something based around Sonos and a Spotify account.
    Budget is £500
    Maybe sonos Connect amp and a pair of £100 speakers from Richer Sounds?
    or
    A pair of Sonos Play 3?
    I think speakers will need to be against wall and no wires on view.
  2. Del monaco
    Del monaco pfm Member
    There are many alternatives out there. Do some research. If you make an appointment any hifi shop can take you through a range of equipment.Sonos would be a good no fuss start but there are some equally viable alternatives from Cambridge audio, Marantz etc than will be worth listening to.Some steamers have built in amps or you may want to listen to active speakers. There's also second hand for added value. If you're into computer audio, an old laptop could be converted to a Vortexbox player or you could convert a raspberry I into a player and connect it to an amp and speakers. I suggest you start with Richer Sounds and do a bit of listening.
  3. Del monaco
    For example, there's a Denon streamer with airplay from Richer. Will be a good bet. You then have £300 for an amp and speakers etc. You'll get a decent set up for that.
  4. Whaleblue
    Whaleblue Southbound
    If going down this route a pair of Play 1s along with a Spotify subscription might be just the ticket. If they buy from Amazon they can always return them if they don't perform as required.
  5. Gerard124
    Are a pair of 1s going to fill a lounge with sound? - if they can great
    They look like something for the kitchen or a bedroom, not seen these in the flesh or heard them but they look very dinky?
  6. thebiglebowski
    thebiglebowski pfm Member
    I had a stereo pair of Play 1's in my 15' 10" x 12' 6" lounge and they were very impressive.
    I bought them when they first came out and even a few naysayers in the original thread I started confessed to being very impressed after they themselves heard them in the flesh.
    http://www.pinkfishmedia.net/forum/showthread.php?t=149443
  7. Tony L
    Tony L Administrator
    Does the family member already have aforementioned iPod (Touch)? If so I'd go for an Airport Express at about 80 quid and a pair of £420 active monitors.
  8. Gerard124
    Not sure, we are going to meet up for a natter and a beer over the coming weeks - I expect he has an iPad and an iPod of some description (possibly not a Touch).
  9. andyoz
    andyoz pfm Member
    Used within their volume limits they are excellent value for money. Just don't expect really loud levels.
  10. ossy
    ossy pfm Member
    I have just bought a sonos play 1, it's fab and is currently in the kitchen. It's not hifi but sounds great, I've tried the streaming route twice before now and always give up because it's too much off a faff. This, however, just works.
  11. Tony L
    iPad is even better. The size storage doesn't matter, it just needs to run Spotify / act as a user interface and to stream the data to the Airport Express, and it is ideal in this role. If he has an iPad (or iPhone, iPod Touch) it's pointless paying money to achieve the same functionality with other kit, and arguably a lot less well. The cash could be sunk into the rest of the system, and going pro-audio active makes a lot of sense there.
  12. Gerard124
    Thanks Tony, are you aware of any speakers that might fit the bill (I'm not!)
  13. Tony L
    I'd checkout the local music shops, e.g. Dawsons in Manchester have a fair few active monitors set up. Price-wise this is the entry level of studio nearfield monitors, but there are still quite a few examples available from Genelec, KRK, Mackie, Yamaha, M-Audio etc. It's a very competitive area and there's a lot of discounting too so shop around. I'd be amazed if you could beat the sound for the same cash with conventional hi-fi kit bought new, though going second hand would give better odds.
    PS I'm assuming you only want digital streaming as mentioned in the OP and served up via an Airport Express. If the user also wants other inputs (e.g. TV sound, CD or even vinyl) then a slightly more complex system is required, i.e. you'd need some form of preamp too.
  14. James Evans
    James Evans Bedroom Bodger
    This is assuming spotify or internet as source. Slightly more awkward for local files.
