Bench/pillar drill advice
Discussion in 'off topic' started by Rodrat, Feb 9, 2019.
  1. Barrymagrec
    Barrymagrec pfm Member
    Yes, I saw that - looked a bit puny.
  2. kennyh
    kennyh pfm Member
  3. gavreid
    gavreid pfm Member
  4. awkwardbydesign
    I bought the Clarke version, similar but lighter weight. Not sure what that says about it, but it was as much as I wanted to spend. Light use so far, so I will see how it goes. I sold a chunkier but shorter pillar drill, as it had insufficient height for the jobs I need it for.
    https://www.machinemart.co.uk/p/clarke-cdp302b-bench-drill-press-230v/
  5. Rodrat
    Rodrat pfm Member
    Thanks for the help. I have arranged to buy Sealey 125b from a PFM. This will suit fine.
    cutting42 likes this.
