Best courier for large items within UK???
Discussion in 'off topic' started by strummer, Sep 14, 2015.
  1. strummer
    strummer pfm Member
    I need to move 2 large boxes or a pallet to London.
    Which is the best / cheapest company out there?
    I once used a website where you put your load details on & hauliers bid for it. Can't remember the name though??
    ta
  2. Barrymagrec
    Barrymagrec pfm Member
    From Croydon to London or from Timbuktu to London?
    Or may be somewhere in between.....
  3. strummer
    strummer pfm Member
    Apologies Barry. I wrongly assumed everyone here knew I'm a norvern monkey.
    Merseyside to Larndon.
    Found it now. www.shiply.com
  4. AndrewM
    AndrewM pfm Member
    I used Palletforce to ship a pallet with a secondhand Rayburn on it from Scotland to Hampshire last year. Price was reasonable and it arrived safely.
  5. strummer
    strummer pfm Member
    Thanks Andrew
    I'm getting quotes from Shiply from £76 - £88.
    2 cardboard boxes of 87cm x 57cm x 54cm, Weight 55kg each.
    Merseyside to Central London.
    I think that's fantastic!!!!
  6. Simon Vess
    Simon Vess pfm Member
    Hi
    I always use UPS. They may not be cheapest but I have found them much more reliable, and unlike many others, the parcel always arrives undamaged
    Avoid UK mail.....I think they kick any parcel marked "fragile"
    Simon
  7. strummer
    strummer pfm Member
    Thanks Simon
    From what I can see, UPS wouldn't take my cargo.
    I went on www.interparcel.com , the weight only goes up to 50kg (mine are 54kg each), so I input at 50kg. UPS didn't come up.
  8. doctorf
    doctorf left footed right winger
    You could try anyvan.com
    They came up trumps for me when shiply failed.
    Simon
  9. strummer
    strummer pfm Member
    Thanks Simon
    Isn't anyvan just the same as Shiply though? IE, just a portal where independent couriers bid for work?
    What issues did you have?
  10. synapse
    synapse pfm Member
    I've used this man with a van site a number of times without incident....in fact it's a great service, though whether better than Parcel2go for your needs perhaps not?
  11. strummer
    strummer pfm Member
    Thanks synapse, but I can't find anywhere on the Anyvan site that allows me to input the dimensions??
    It's quite large & heavy (2 cardboard boxes of 87cm x 57cm x 54cm, Weight 55kg each)
    I input that on Parcel2Go & they want £160 for 48hr delivery & £190 for next day.
  12. synapse
    synapse pfm Member
    unsure if they've changed the format but there is somewhere where you can give a description of the items and then drivers bid for your custom at which point you can get into some correspondence with them?
  13. strummer
    strummer pfm Member
    Ah OK, maybe I could manually write the weight & dimensions in the Description box.
    Have to say the Shiply website is a lot better.
  14. doctorf
    Yes it is the same sort of thing.
    I just found Shiply less responsive and more expensive but you may well find different.
    Simon
  15. doctorf
    I doubt you will get much better than your Shiply quotes.
    A couple of weeks back I had to do a couple of deliveries of very heavy items and I found it cheaper and more effective to hire a van and do it myself.
    480 miles in a Vauxhall Vivaro van. £48 to hire for the day and I got 42 mpg.
    It's what being retired is all about!!
    Simon
  16. Barrymagrec
    A friend of mine who needs to ship a couple of large heavy boxes - blanket wrap - from London to Devon is using these people :-
    https://www.uship.com/uk/
    It`s another set up where they just bid for the job, I think.
  17. strummer
    strummer pfm Member
    Thanks for the input guys.
    I booked it on Shiply. Collected at 17.30 yesterday, delivered by 11am this morning in central London, exactly as they said they would.
    How they do it for that price, I don't know.
  18. doctorf
    Because they ship all sorts of stuff in the same van.
    More profit for them and less expensive for you.
    Everyone wins!
  19. EigirdD
    EigirdD Guest
    Hi! If you still need recommendation about parcel delivery company, i can recommend Parcel ABC. I chose them few times and will choose it again. The best thing that they do door 2 door! I think this recommendation will be useful for you in the future. More information about their services and prices are in Parcel ABC site: https://www.parcelabc.co.uk/
  20. Konteebos
    Konteebos Traitor Re-joiner
    I've used Paisley Freight a few times for large items without any problems. They sub-contract the work to other freight forwarders. They can supply pallets if you need one.
