Best ROBOT vacuum cleaner? R2D2 sucks?
Discussion in 'off topic' started by JimmyB, Sep 9, 2019.
  1. JimmyB
    JimmyB pfm Member
    So as not to highjack the cordless thread, I thought I'd ask if anyone has any experience of robot vacuum thingies and what features are musts and how much to you need to pay to get something that works.
    Basis is a new engineered wood floor going in soon, most likely with a rug in one area and this will be linked to a tiled hallway and laminate kitchen. Seems eminently suitable for an Asimov style intervention but if it's just going to be a waste of money I'll just stick with a decent normal one.
    P.S. Dyson is out due to right wing Brexit tendencies......
    ff1d1l likes this.
  2. stevec67
    stevec67 pfm Member
    I bought a cheap one, great for perfectly flat floors, useless on lumpy ones, couldn't handle a rug.
  3. richardg
    richardg Admonishtrator
  4. gassor
    gassor There may be more posts after this.
    "I sold my vacuum cleaner last week; it was only gathering dust". Tim Vine.
    Rob998 likes this.
  5. gintonic
    wow suck that up
  6. JimmyB
    JimmyB pfm Member
  7. Rug Doc
    Rug Doc pfm Member
    They will either not ride up onto a rug, or if it does it will be quickly destroying the ends and sides of it in the process.
    Don’t bother if you have nice rugs.
  8. JimmyB
    JimmyB pfm Member
    Still to get rugs and hoping to get quite a deep one I suspect. Didn't think of it knackering the edge though, that's a good bit of info.
  9. richardg
    this advert shows a robovac going over a very shaggy rug....must mean it works then.
  10. JimmyB
    JimmyB pfm Member
    I've given up on the 'Best XX things of 20XX', purely online researched with no actual experience with the products and most likely just disguised advertising/propaganda.
    Just had a demo of a Roomba in John Lewis......not sure of the model number but several hundred quid and it failed on the rug we were thinking may be nice when we get the room finished. That was easy in the end, if ~£500 worth of robot can't manage a rug convincingly then no point.
