Chromecast Audio alternatives for HiFi use
Discussion in 'audio' started by cjarchez, Jul 8, 2019.
  1. cjarchez
    cjarchez pfm Member
    Dug out the old HiFi for causal use and thought a CCA would be nice on there for my android phone.
    However, I remembered that Spotify can't do normalised volume via a CCA.
    Therefore, before I hunt one down is there any other budget priced gadget that does the same thing with Spotify volume normalising working?
  2. H20GNA
    H20GNA Active Member
    The volume normalising is within Spotify app, nothing to do with CCA.
    Gary
  3. cjarchez
    cjarchez pfm Member
    Aye, it works via headphones but not via CCA, a defect in the app as you say and hence the question as despite the many requests on their forum, I can't see a fix materialising now the stand alone CCA itself has been killed off.
  4. The Far North
    The Far North pfm Member
    Why not just use a 3.5mm jack in the headphone socket to twin RCAs plugged into the hifi? That's what I do with my Android tablet.
  5. wd40addict
    wd40addict pfm Member
    Bluetooth receiver connected to the Hi-Fi?
  6. mandryka
    mandryka pfm Member
    I believe it can with the Logitech Media Server, search the squeezebox forum website or ask a question there about it -- you could make yourself a streamer with Rasberry Pi, or maybe still use chromecast from LMS, there's an app for this.
    Some people say it has a negative impact on sound quality by the way -- I get unsatisfactory sound through spotify.
  7. Chefren
    Chefren pfm Member
    I turned off normalising in Spotify since I found it (at least subjectively) contrained dynamics a bit. The Bluesound Node 2i does support ReplayGain but it's not a budget device compared to the Chromecast.
  8. cjarchez
    cjarchez pfm Member
    Thanks for the comments.
    In answer;
    Bluetooth is too unreliable and limited range.
    Phono to 3.5mm is ok when settled and not wanting to use the phone, otherwise....
    Like the Node 2 but not the price.
    LMS! Thanks for the nod, I shall investigate, first glimmers of hope here....
    https://audiokarma.org/forums/index.php?threads/lms-and-chromecast-audio-success.695843/
    Re SQ changes, I really assumed there would be, this is not for critical listening.
  9. Jason P
    Jason P pfm Member
  10. cjarchez
    cjarchez pfm Member
    Nice unit but works via built in CC, = same problem unfortunately.
    "Enables streaming of Spotify, SoundCloud, TIDAL, TuneIn, own music and 100+ more via Chromecast"
    Unless you know different?
  11. Jason P
    Jason P pfm Member
    Nope, I'd just misunderstood your requirements :)
  12. vince rocker
    vince rocker pfm Member
    LMS sees my CCA devices through Chromecast Bridge and they appear as devices alongside my Touch. I don't recall actually installing Bridge, it was just there in the plug in list. Working well 99% of the time, just occasionally one device disappears and I have to go into LMS plug in settings and restart Bridge.
  13. jtrade
    jtrade pfm Member
    Just get a long cable, as well as a long charging cable - I have 3 or 5m, so it reaches the nearest sofa - so the phone can charge whilst playing music
    & you can use the phone if required.
    No idea how good the onboard DAC on your phone is : iPhone 6 Plus onwards has an excellent DAC (somewhere near bottom of this review https://kenrockwell.com/apple/iphone-6-plus.htm).
  14. eisenach
    eisenach European
    I thought I'd revive this thread just to say I can't believe how good Chromecast Audio sounds. I've dug out an old Cyrus 1 amp and a pair of Maudaunt Short 05 speakers, a phono socket adapter to plug into the Chromecast, a couple of old Chord interconnects and some bit of speaker cable and set it up in the bedroom. It sounds far better than it should!
    Bubble app on the phone and it's pulling everything off the NAS. Great! Sometimes it makes you wonder why I bother with the other stuff!
  15. The_Wizard
    The_Wizard Active Member
