DIY Shielded main cable (Uk plug/IEC)
Discussion in 'audio' started by Rack Kit, Feb 14, 2020.
  1. Rack Kit
    Rack Kit pfm Member
    Trying to find longer lengths of shielded mains cable other than the standard 1.5m hasn’t gone so well so far. I need around 4-5m so looking at going DIY but can’t seem to find any shielded cable out there.
    if anyone has any links, let me know.
    Cheers,
    Rack.
  2. Bourneendboy
    Bourneendboy pfm Member
    Belden 19364. Plenty of seller's on Ebay.
    ariegur and Rack Kit like this.
  3. Fourlegs
    Fourlegs Trade: WAVE High Fidelity digital cables
    You need to search for Control Cable. I use Belden CY 2.5mm2 3 core shielded. The Belden part number is CYSE03.0050.
    I buy mine from RS Components and their stock number for it is 363-395 for a 50m reel. Hopefully that is enough to go on to get some cut to length from a supplier, possibly on eBay.
    Rack Kit likes this.
  4. Andrew C!
    Andrew C! Been around a while....
    If you don't want to make your own, then Mark Grant Cables can do what you require, and at reasonable prices IMHO...
  5. Ian G
    Ian G Active Member
    Local Medlocks , CEF or Edmondson electrical wholesaler would likley have screened CY cable in stock that you can by by the meter.
  6. Rack Kit
    Rack Kit pfm Member
    Thanks for heads up everyone.
    Cheers, Rack.
  7. Rack Kit
    Rack Kit pfm Member
  8. DirkDiction
    DirkDiction Member
    Ive used 1mm SY cable before now with the braided screen connected to the earth pin at the plug end, a slight improvement in grip over standard mains cables. I’ll ask my wholesaler about the Belkin cable - hopefully there’ll be a job I can book it to...........
  9. Yomanze
    Yomanze pfm Member
    I recommend Supra LoRad because it’s dead easy to work with. It doesn’t need any attention to the shielding, just strip and connect the 3x wires.
  10. stevec67
    stevec67 pfm Member
    What do you do with the shielding them, just strip a bit off and connect it to E?
  11. Barrymagrec
    Barrymagrec pfm Member
  12. Yomanze
    Yomanze pfm Member
    There are two versions. There is the MK1, where the earth conductor's insulation is semi-conductive, and in contact with the screen.
    The MK2 does use a seperate drain wire...
  13. AndyU
    AndyU pfm Member
    Why mess about with a metre or so of shielded mains cable when it’s not that difficult to go the whole hog and screen all the way back to your consumer unit. Aaronia sell all sorts of rf and EMI screening products, included screened twin and earth.
    https://aaronia-shop.com/products/abschirmungen/geschirmte-kabel
  14. mansr
    mansr Well-Known Member
    Why mess about with shielding a metre of mains cable when there's miles upon miles of unshielded wiring between the socket and the power plant? I can see the merit of using shielded wiring in a some industrial setting with high levels of EM noise, but there the whole building would be using it. In a normal home, the EM noise levels are not high enough to require such measures.
    Of course, a shielded power lead won't do any damage either, so experiment away. Just be careful to get the wiring right. A faulty power cable can be lethal.
  15. Craig B
    Craig B Re:trophile
    I am reminded of the bright spark who leaves the door open on the Faraday cage.
  16. AndyU
    AndyU pfm Member
    I always keep my eye on weather conditions in space, particularly sunspot activity. No point in listening to your hifi if there’s a geomagnetic storm coming.
    https://www.swpc.noaa.gov/products/3-day-forecast
