Help identifying a pipe?
Discussion in 'off topic' started by ks.234, Feb 6, 2019.
  1. ks.234
    ks.234 pfm Member
    Can anyone help to identify the pipe below?
    I bought it 30 odd years ago in Salisbury and sat down on it in my back pocket to much wailing and gnashing of teeth.
    I have half a memory that it was a local maker, maybe Devizes?
    No rough shag jokes please!
  2. blossomchris
    blossomchris I feel better than James Brown
    Knocked your pipe out there.
    You could always convert it to a cigarette holder.
    Bloss
    Pete MB&D likes this.
  3. Mullardman
    Mullardman Moderately extreme...
    If I'm not mistaken, the stem immediately behind the bowl bears the legend 'London England' ..which is a fair way from Devizes...
    ks.234 likes this.
  4. Barrymagrec
    Barrymagrec pfm Member
  5. ks.234
    ks.234 pfm Member
    Yes, I should’ve got that!
    All other markings are illegible btw, some sort of inscription (3 letters/symbols inside a diamond??) on other side of stem
  6. gintonic
  7. ks.234
    ks.234 pfm Member
    Post Brexit you mean?
    gintonic likes this.
  8. gintonic
    I added some sensible recommendations to my post above
  9. Mullardman
  10. mandryka
    mandryka pfm Member
  11. sq225917
    sq225917 situation engineer
    Drill it out and insert brass Bush. Simples. Youll need a sharp bit and good clamp.
    ks.234 likes this.
  12. Barrymagrec
    My Dad used to glue his broken pipes with Araldite and strengthen the joint with Heatshrink sleeving. It was unfortunate that in those days he only had yellow heatshrink.
  13. Still
    Still he said his naim was ralph
    Disappointing, as I was hoping this thread related to the exploits of @Mullardman.
    Mullardman and Jamie like this.
  14. cjarchez
    cjarchez pfm Member
    Looks more like post Breaks-it to me :D
    TimF likes this.
  15. sean99
    sean99 pfm Member
  16. gintonic
  17. MikeMA
    MikeMA pfm Member
    Why don't you just buy a new pipe?
  18. ks.234
    ks.234 pfm Member
    I would, but I can’t find one like the one I’ve broken; small, small bowl, straight, unfussy....
  19. thebiglebowski
    thebiglebowski pfm Member
    Looks like a straight Danish Dublin.
  20. thebiglebowski
