Help me find a turntable
Discussion in 'audio' started by Sgt pepper, May 15, 2018.
  1. Sgt pepper
    Sgt pepper pfm Member
    After some bad experiences with new turntables recently I have been advised by the guys over on HiFi Wigwam to go with used, as I will achieve a bigger bang for the buck. So I am posting the same question here.
    About £320 limit and something for a relative newbie that will be easy to look after. Any help will be much appreciated in my quest, for turntable nirvana;) (or just something that is really good):)
    Barry
  2. mercalia
    mercalia pfm Member
    possibly a Rega Planar 3/2 with RB300/250 arm? They are simple designs with little to go wrong with a good arm
    Sgt pepper likes this.
  3. david ellwood
    Another vote for the rega planar 2.
    You aren’t going to get a better deck for the money you have to spend.
  4. raysablade
    raysablade pfm Member
    Under budget and any colour you want as long as it's black or white.
  5. Rockmeister
    Rockmeister pfm Member
    Is that £320 complete? ie with arm and cartridge? And do you have a phono stage which will work with your cartridge?
    if yes to all the above, I'd be looking for a japanese direct drive turntable from the 80's or 90's from a firm known for solid engineering in that time, but not one enjoyed by wannabe DJ's. Sansui, Sony, Denon or Pioneer probably. If it doesn't come with a cartridge then an AT MM will suit well.
  6. stevec67
    stevec67 pfm Member
    Look hard and you will find a rega P3 at under £200. I got one for £150 about 5 years ago, great deck. It's a mile better than a P2. See also the Sansui 222, about £150. Systemdek, Thorens 150/160 will come in budget.
  7. Sgt pepper
    Yes looking to purchase used about £320, I have a decent cartridge (Ortofon 230MKII), I like the retro look, the Rega and Projects no longer do it for me.
  8. divedeepdog
    divedeepdog pfm Member
    I've got a Denon DD here in excellent cosmetic condition, and could probably get it near you in a couple of weeks.
    Rockmeister, foxbat and Sgt pepper like this.
  9. Joolzdee
    Joolzdee pfm Member
    +1 for one of these. I recently picked one up (from a different dealer) and although advertised as a "second" it's completely un-marked. And sounds great too.
  10. Seanm
    Seanm pfm Member
    What were the bad experiences you had with new turntables? If they had to do with them not working quite as they should then I don't know that you'll fare any better with older turntables: there'll always be something - a slightly noisy motor, a suspension that can't quite be levelled, a sloppy bearing, a warped top plate, failing arm wiring, loose motor pulley, slightly inconsistent speed (and this is just the ones I currently own). Most of it can be sorted but it can be a faff. Of course if you can get something on here that has been sorted then no problem. Or if you can live with minor imperfections then also no problem (I'm currently listening to a Thorens TD125 with a bent motor shaft and it sounds really good). Thorens? Systemdek? Maybe with an RB250 from Audio Origami (£100).
  11. raysablade
    This is some way out side your budget but seems to fit the rest of your criteria, comes with a warranty and looks almost good enough to eat. You could probably sell your cartridge to fund some of the gap.
    PS .....and if you buy it, you will save me.
    Rockmeister and Sgt pepper like this.
  12. Sgt pepper
    Looks fantastic but as you say way above what i can afford.:(
  13. Ptah
    Ptah pfm Member
  14. stevec67
    stevec67 pfm Member
    I'd choose a Thorens 160 super over a Rega P3 for £200 all day. You get them at that price, I sold mine for that on here. Actually maybe a bit more but it had a 3009 on it and they are worth £150+ on their own.
  15. divedeepdog
    £150 3009 will cause a stampede, prices have moved on ...
  16. Sgt pepper
    I want to thank everyone for the fantastic efforts in helping me find a Turntable. I am now sorted and purchasing a Linn Axis from one of the members on here, I can't wait to take delivery of it hopefully quite soon.:)
    divedeepdog likes this.
  17. raysablade
    Glad you are sorted.
    Might it be worth expanding on your bad experience in the Onkyo thread? As it stands others might act on your positive assessment.
  18. linnfomaniac83
    I often forget about the Axis but it’s actually a great performer for the money. I’m sure you’ll get plenty of enjoyment out of it.
  19. Noris
    Noris pfm Member
    A Thorens TD 320 or 321 would be my choice for a good cheaper belt drive. Easier to set up and some say slightly better than the 14x/150/16x range.
    I have here a TD147 with an OC 9 (very similar to a TD160), a Linn Axis with a Basic tonearm (vintage Grado system) and finally a stock Lenco L70 (Denon DL103r)
    My favorite is the Lenco followed by the TD147. But all depends on condition and synergy.
    I had many years an Axis with Akito. Maybe I am just a bit tired of it.
    Or maybe a Japanese DD?
