HiFi Stand Stacking Order
Discussion in 'audio' started by Flibbles, May 22, 2020.
  1. Flibbles
    Flibbles Active Member
    Just looking at everyones system pics and wondering if there is a set rule as to what order the different seperates should be in on a hifi stand? I always presume the source should be at the top then the pre amp then the power at the bottom. Is that right?
    I feel like there may not be a lot of difference sonically and it is just easier to have the CD player at the top so you dont need to bend down as far but maybe there is some science behind this order. If so why?
  2. Strictly Stereo
    I try to stack things according which pieces are connected to each other (source > preamp > power amps). Whenever possible, I also prefer to put the heaviest items at the bottom, which usually means that the power amps are at the bottom.
    maccar, Mike P, clap and 1 other person like this.
  3. Darren L
    Darren L pfm Member
    Normally or traditionally your TT or other source components would be placed on top, a record player would be quite awkward to operate in a middle shelf, then your may have your preamp or intergrated or other source components, tuners, Dacs, etc then perhaps your power amp or power supplies at the bottom, but I don't think there's any hard and fast rules or science, just common sense, big heavy power amps at the bottom, manual controls for sources and pre at a convienent height for operation.
    Nowadays a lot of equipment, especially the digital stuff is controlled by remote perhaps even a phone or tablet, I suppose the lack of manual interaction means this sort of stuff can be placed at any height.
    Edit: I personally think it's good practice to have power in one side and signal to the speakers out the other and to keep power and signal cables seperate, though this is not always possible but should perhaps be taken into consideration when placing the various components.
    Sometimes components like SUT's or solid state class A and valve amps require further considerations due to noise or hum and heat disapation
  4. Del monaco
    Del monaco Del Monaco
    Mine are stacked according to what I use most and ease to get to. So I have my turntable at eye level on a wall stand. Below and on the top shelf of my rack I have my Squeezebox, phono amp And Dac. Below this my amp. Then my tuner followed by my CD player and lastly my cassette deck. Works much better for me and I like to get to things to my most used machines without crouching too muc.
  5. uncl_nigel
    uncl_nigel pfm Member
    Same here.
    If the first priority is safety the heaviest is always at bottom - nobody wants to see their turntable crashing down on their grad daughter because the rack is unstable and top-heavy.
    For the same reason, my CD shelves are screwed to the wall at the top (where you can't se it from below.
  6. Snufkin
    Snufkin pfm Member
    Although I normally place the heaviest at the bottom, it just sensible, there have been occasions when an amp has been placed at the top because of heat dissipation/ventilation.
  7. Del monaco
    I also like the amp near the top because it’s easier to get to the majority of wiring terminals etc.
  8. zippy
    zippy pfm Member
    Not just any height, but any location - e.g. for a while I had the power supply behind the other equipment where I couldn't see it (only because the cable was too short to reach the other boxes though)
  9. mikemusic
    mikemusic pfm Member
    Source/s at the top, Pre Amp next
    Power Amp below that with any PSUs and dirty stuff at the bottom.
    All assumes cables long enough.
    Two racks if suits with 'clean' and delicate on one and heavy and 'dirty' on the other
    Del monaco likes this.
  10. Jonathan
    Jonathan pfm Member
    ergonomics. most accessed components within easiest reach. tt on top then preamp below etc
  11. wylton
    wylton pfm Member
    A stacking-order thread; I though that was the province of the Naim forum!
    Snufkin likes this.
  12. Del monaco
    I thought about that when I saw the post.
  13. YNWOAN
    YNWOAN 100% Analogue
    What you really need is three separate equipment racks/stands ...... ;).
    This has the added advantage of reducing the need for furniture - as there is now much less space for it.
  14. Bob McC
    When I used racks/tables I put the turntable on its own with nothing else.
  15. Rug Doc
    Rug Doc pfm Member
    I stack things in the order that I think looks best, simple as that.
  16. stevec67
    stevec67 pfm Member
    It's good practice to keep mains transformers out if the way of signal cables, phono stages etc. A big amplifier with a trafo on say the left hand side doesn't want a phono stage standing above its top left corner if you can avoid it.
  17. Theo
    Theo pfm Member
    I've always preferred my sources close to eye level, which - for me - requires wall shelves. The rest of the equipment sits on record storage units, but I'd be quite happy to hide them in furniture (a future plan).
  18. suzywong
    suzywong Wot, no electrons?
    From bottom to top
    NAP 250
    NAP 250
    Supercap (SNAXO)
    Supercap (NAC 82)
    XPS (NDAC)
    SNAXO, HiCap (Stageline)
    NAC 82
    CDX
    NAT 05
    Lingo, NAPSC2, Allo Shanti
    NDAC
    Allo USBridgeSig/DigiOneSig, Stageline
    Sondek LP12
    I’d like to split the rock into two (Putting on an LP currently needs a step ladder), but I would have to first relocate a cupboard’s worth of camera gear.
  19. cjarchez
    cjarchez pfm Member
    When such things were important to me and I had a system worth fussing over.
    There were two stacks. From memory turntable atop one, with it's psu and and 2/3 width pre amp below. Under that was a DIY switching box for extra units and to handle AV. Thereafter was a HiFi vcr, AV add-on unit.
    Second stack was CDP on top, tuner, cassette deck and then 3&1/2 big lumps of amps, xover and psu
    The stands were modular, round legged tripod system where the spikes of each discretely isolated each shelf i.e. the spikes went inside the leg and were adjusted so the gap was minimal and the spikes invisible. Black only with mdf or similar shelves, though I repainted mine white.
    Can't remember the name of them, but were highly regarded in the day.
    Basically placed in order of physical attention required.
  20. wylton
    wylton pfm Member
    Now that's what I call dedication!
    I may as well join in (main stack only):
    NAP250
    ZAP250
    CDPS
    Auralic Aries Mini + Linear PSU
    Avondale stage 1 phono stage + NAXO
    NAC 102
