How much difference between streamers when using own dac?
Discussion in 'audio' started by Allaboutmusic, Jan 4, 2019.
  1. Allaboutmusic
    Allaboutmusic Member
    Hi all, I currently use a cca into a rega dac-r, the cca outputs via the optical into the rega dac which then reclocks the data so it should in theory remove jitter. I have read elsewhere that for a optical output to work all data needs to be sent or it won't work, so coupled with the dac there should be zero jitter and a bit perfect stream. At least in theory.
    However I was in an hifi store and the staff said you can tell the difference. I might audition a few with my dac and see if I can hear a difference but wanted to see what others views are? Will the quality of streamer have an impact or is it really just features providing using own dac?
  2. Purité Audio
    As long as the ‘transport’ is sending bit perfect data there will be no difference.
    Keith
  3. uncl_nigel
    uncl_nigel pfm Member
    Sorry Keith but my ears tell me otherwise.
    The dCS Bridge is definitely better than my Moon Mind180 when it comes to sound quality. It is also much more expensive :-(
    clap likes this.
  4. Purité Audio
    Compare unsighted through the same dac.
    Keith
    Emlin and March Audio like this.
  5. uncl_nigel
    That is what I did.
    Mind you, with my sight that is rather easily done :)
    Iceman16 and Cereal Killer like this.
  6. simon g
    simon g Grumpy Old Man
    This is a topic that comes up on here, and elsewhere, again and again. Just do a search.
    IMO&E the streamer does make a difference, the significance of that difference is down to your personal preferences, system and budget.
  7. Del monaco
    Del monaco pfm Member
    There was an interesting Archimago article which appeared to contradict this view. It included measurements. I tend to agree with it, having tried a range of streamers.
  8. Strictly Stereo
    What article are you referring to here? Archimago seems to only test entry level streamers and then extrapolates conclusions about higher end components.
  9. formbypc
    formbypc pfm Member
    Keith/Purite "As long as the ‘transport’ is sending bit perfect data there will be no difference."
    "Sorry Keith but my ears tell me otherwise."
    Keith/Purite "Compare unsighted through the same dac."
    "That is what I did."
    Silence from Keith.
    Mr Cat and The Chronicals like this.
  10. Del monaco
    It’s on his site, most recent article I think. I’ve tried a few streamers in my friends set up( he has very revealing speakers)including Aurender, Linn, Naim, Innuous etc. Blowed if we could hear much difference through his dcs dac.Even with a Pi based streamer gave competition.
  11. Del monaco
    I must try the CCA into my dac. It appears to have a good amount of followers.
  12. mandryka
    mandryka pfm Member
    Anyone got any ideas about how that could possibly be?
  13. narabdela
    narabdela who?
    Naughty! :D
  14. zippy
    zippy pfm Member
    I can tell no difference in quality between using my streamer, and connecting a laptop directly to the DAC.
    For me therefore the only difference between streamers is their functionality.
  15. simon g
    This is just all part of the same old same old. Do CD Transports make a difference? Cables? Supports? Et al
    There's no consensus, just the old subjective vs objective debate. My experience tells me what does and doesn't matter. Proving, or otherwise, what I hear is pointless. I really don't care. I just pass on my opinion based on 45 years experience, having owned more kit than many dealers!
    Dozey, duckworp and webster like this.
  16. Del monaco
    It comes down to vfm for me. If I here no difference it makes me feel really good that I’ve spent less than £100 on something that sounds very similar or the same as a £2000 + streamer.
  17. Purité Audio
    Over active imagination.
    Keith
    JTWzen, Emlin, March Audio and 2 others like this.
  18. Ginger
    Ginger pfm Member
    So what's the cheapest off the shelf streamer?
  19. Del monaco
    You could probably buy a 2nd hand Squeezebox Touch or roll your own with a Pi. I’m sure there are others.
  20. Moppit
    Moppit pfm Member
    I can speak from my own personal experience. Whilst the CCA has fantastic functionality (multi-room etc), integration with Google Home (voice control etc.), there is a noticeable difference when using my Allo digione in place of the CCA feeding my 2Qute DAC. Not as much as changing the DAC but there is an increase in detail and separation. Having said that the Digione is via Coax input and the CCA is Optical on the 2Qute - I think I read somewhere that the Coax is less prone to jitter hence why Allo use this. I can switch between the CCA and the Digione with the same track, same source (NAS, spotify, internet radio etc.). Radio paradise flac sounds better via the Digione. I tend to use the CCA for all house background music and the Allo Digione for single room listening sessions.
