Hybrid SACD - CD layer
Discussion in 'audio' started by wpm, Nov 26, 2018.
  1. wpm
    wpm pfm Member
    Hi
    I had a query..
    I see mainly 3 types of CD''s available on music websites like elusive disc
    a. Hybrid SACD which has a Redbook CD layer so this can be played on normal CDP - price about USD 30 each
    b. Normal CD - price about USD 15 maybe..
    c. Blue Spec CD - compatible with CD players - this is Japanese spec - Japanese site - about USD 15
    My CD Player is a normal CD Player and reads ONLY CD-R
    Philips CD 960 - dont intend to buy asn SACD player anytime soon
    Will i hear more or better recording is i buy a Hybrid SACD and play it on my CDP OR there is no point buying Hybrid SACD but stick to normal CD's ??
    regards
  2. windhoek
    windhoek The Phoolosopher
    The answer is it depends: if the mastering is better on the CD/SACD hybrid then buy it. If it's the same or worse then buy the standard CD.
  3. wpm
    wpm pfm Member
    Thank you..
    how would i know which mastering is better ?
    is there a way to determine this before purchase and with no audition ?
  4. windhoek
    Sort of: you can compare dynamic range scores at DR Database - in general, the higher the score the better the mastering is, although it's not always going to be the case - and you can also use forum knowledge and experience to see what the consensus is as to which release is better, although in some cases this will lead to a few releases being touted as the best which, if nothing else, will help rule out the worst versions. My view is, if you don't plan on buying an SACD-capable player anytime soon if ever at all you'd be as well to forget about SACDs and just get on with enjoying the music you already have along with any CDs you buy in the future.
    wpm and mikechadwick like this.
  5. smegger68
    smegger68 Mango Enthusiast
    The dynamic range database is a good indcator of how well mastered a given disk is.
    http://dr.loudness-war.info/
    wpm likes this.
  6. Mike Reed
    Mike Reed pfm Member
    Brilliant, but how do you find the artiste or specific CD as it's not alpha order or even year order?
  7. SteveS1
    SteveS1 I heard that, pardon?
    Just type the artist or title into the search box(es). It is a database with search facility.
    I would just caution a bit on this. The DR is a useful function, most useful for identifying obviously overly squashed dynamic range on some editions. But IME the clumsy use of noise reduction or eccentric EQ choices are just as annoying. Smiley faced EQ or goosed upper mids to give the impression of 'detail', or jacked up mid bass for 'punch' are very common and DR database won't help locate those. Music forums like Steve Hoffman's will help identify some decent options for favourite albums.
    Mike Reed likes this.
  8. windhoek
    Once you've searched for your chosen artist/album, you can click on the columns at the top to sort the list by year, DR max, etc. As already noted, high DR is no guarantee of good mastering but it can help pick out the ones to avoid when there are album releases with extreme DR scores.
  9. tuga
    tuga European
    The DR database will only provide information regarding Dynmic Range but there's to sound than DR so it might not be a bad idea to buy two or three different mastering version and compare them.
    You may find complementary information about the best version of a particular album here http://forums.stevehoffman.tv/forums/music-corner.2/
    wpm likes this.
  10. onlyconnect
    onlyconnect pfm Member
    However it doesn't tell you about the source tape used, or the EQ applied, or the ADC, or other variables that impact the sound quality.
    Tim
  11. onlyconnect
    Not really because it is in part subjective. And there are trade-offs, for example would you rather put up with some hiss or suffer NR artefacts?
    Tim
