[FS/SWAP] iFi iPower 15V power supply
Discussion in 'classifieds' started by Maxbertola, Feb 15, 2020.
  1. Maxbertola
    Maxbertola pfm Member
    I have the as per above, that I used with a Pro-Ject TT that's now sold. I now need a 12V good PS so if someone has a 12V iFi iPower and needs a 15V, I'd happily swap. It is, as you can see from the pic, mint and complete.
    Alternatively, I'd sell it for any reasonable offer (it cost me €55 shipped from the Italian distributor on Feb 14th, 2018, receipt) plus some kind of agreement on shipment.
    Thanks for looking
    M.
  2. Maxbertola
    Ok, I'll try to post a better pic.
  3. loosend
    loosend Subsequently unresponsive
    May be worth checking the current output on it as it will be the correct voltage for an Aurelic Aries Mini and that would no doubt entice people as they are very popular
  4. Mynamemynaim
    Mynamemynaim 35yrs a Naim owner
    Can it not just be opened up and turned down to 12v ??
    Most power supplies are at least a little adjustable...and that's only 3 volts needed
  5. Maxbertola
    @loosend
    Hi,
    I am not sure I got it.. The output is 15V exactly and, for what I have seen of the Auralic Aries Mini, hasn't it its own internal PSU?
  6. Maxbertola
    @Mynamemynaim,
    yes, that's a chance. I could see if a) it has screws to give access to internal, and b) if it has a trimmer. iFi makes this iPower PSU for 5, 9, 12 and 15V respectively as separate units, it could be that it's a basic design with a regulation trimmer. If it's about soldering off and changing some component I'd rather buy a new one. Thanks anyway for the hint.
  7. Maxbertola
    Ops, I forgot... Sorry, EU only.
  8. Maxbertola
    @loosend
    I checked better and you're right, the Auralic Mini has a socket for an external wall-wart PSU.
  9. loosend
    U would just need to check current draw, if it’s overfilled enough I’d relish it it and put for Aries Mini or words to that effect in the title, someone would no doubt want it as a cheap upgrade over the switch mode one supplied with it as standard
  10. Maxbertola
  11. Maxbertola
    I can't change the title of the thread. Who's interested will hopefully read it and know what he's looking for.
    Thanks,
    M
