Linn Keilidhs - about to go active - advice!
Discussion in 'd.i.y.' started by Dan Scofield, May 23, 2020.
  1. Dan Scofield
    Dan Scofield New Member
    Hi all, first post here so apologies in advance for any newbie terms I use.
    Right, just about to make the Aktiv leap with my system (Linn Kolektor/2 x LK85/Axis/Meridian 507/Keilidhs)
    Plugging the stereo cards into the 2 LK85's is straightforward so no issues there.
    Haven't looked into the Keilidhs yet, but I intend to use only the 2 amps to drive them actively. At the same time as altering the wiring on the crossovers, I have a set of 3 bar tweeters to upgrade the earlier mesh ones.
    Instructions say to cut the four links and resolder two wires. Taken a look inside and is one of the links (link 4) not a bridge to maintain using only one Lk85 to drive mid/bass? Do I use the active bass connection on the rear for the banana plug connection, or leave in the middle as with the passive setup (suspect this is dependant/irrelevant due to any internal bridge!)
    Thanks to anyone more knowledgeable than myself in advance before I go blowing anything up unnecessarily!
  2. Dan Scofield
    No linnies about? :(
  3. Mike T
    Mike T Member
    I am a rookie to Linn but look up a member named Linnfomaniac...He has helped me with Tri-amping my Linn system and I am sure would be able to help you with your system. Best!
  4. sunbeamgls
    sunbeamgls pfm Member
  5. stevec67
    stevec67 pfm Member
    Linnfomaniac83 here can give you chapter and verse on this.
