Low cost room correction methods
Discussion in 'audio' started by The Bish, Mar 25, 2020 at 8:53 PM.
  1. The Bish
    The Bish pfm Member
    Hi all,
    Can anyone point me in the direction of a good beginners guide to room correction for someone starting from scratch and wanting to do it as cheaply as possible?
    Cheers and hope you are all bearing up.
  2. tuga
    tuga European
    Do you mean acoustic treatment or signal processing?
  3. The Bish
    The Bish pfm Member
    measurement and processing please, which I guess might lead to recommendations for room treatment as well as processing?
  4. tuga
    tuga European
    First step is to buy a UMIK-1 USB measurement microphone.
    Then download RoomEQ Wizard and perform measurements of your room.
    AV Nirvana, the home of REW, is probably the best site to ask for guidance in these matters.
  5. zippy
    zippy pfm Member
    RoomEq wizard is indeed a good start, but the UMIKS are expensive, so borrow one if you can !
    There's a definite art to room measurement so be prepared for some learning !
  6. barryb
    barryb pfm Member
    As above. One can then input the Room eq wizard filters into Roon for example, which is available for free demo on sign-up. You could assess whether room dsp is to your liking then, and worth further investment or exploration. It's a good tentative first step/ litmus test.
    Most say DIRAC is best and most user-friendly, though it seems largely hardware driven at the minute, ie standalone demo/download for PC/ MAC not available.
    Cheap Mini-DSP modules can also accept room eq filter recommendations. Some like the DDRC-24 can use both DIRAC and Room EQ, as well as proprietary EQ and filtering.
    There are other software solutions available too, Sonarworks for example.
    Most everybody with experience will tell you to correct up to approximately 300 hz only. Also, most will also tell you that Room DSP, while eminently useful in certain situations, is not a panacea. Something else we could do more with at the minute... ;)
    Edit: https://community.roonlabs.com/t/a-guide-how-to-do-room-correction-and-use-it-in-roon/23800
  7. The Bish
    The Bish pfm Member
    Thanks all, will get that measurement mic hopefully secondhand and start learning from there.
  8. Paul Burke
    Paul Burke pfm Member
    Well worth a read to cover the first few parts and basics. Roon is very good for this if you can set up a trial too. It’s dsp engine has a lot of options, really get into it and can even use its convolution feature to go full on linear phase too. Lots to explore
    https://www.roomeqwizard.com/help/help_en-GB/html/
  9. al2002
    al2002 pfm Member
    Run, do not walk, to your keyboard and order this:
    https://www.paradigm.com/en/wireless/pw-link
    It is a stand alone box featureing Anthem DRC. Microphone included. It is the least expensive way to try out DSP based room correction.
    You can use REW to measure your system before and after .
  10. al2002
    al2002 pfm Member
    Bish, whether you get the Anthem box or not, a calibrated microphone is an absolutely essential tool if you want to learn what your room is like, acoustically speaking.
  11. al2002
    al2002 pfm Member
  12. The Bish
    The Bish pfm Member
    Thanks Al. Can’t find that Paradigm box for sale in the UK - any idea where I could source one?
    @Paul Burke thanks for that link, loads to learn there
  13. al2002
    al2002 pfm Member
    Bish, best to order direct. I am based in the US and ordered direct from their site.
  14. cnocmoy10
    cnocmoy10 pfm Member
    + 1 for RoomEQwizard
  15. Hoopsontoast
    Hoopsontoast pfm Member
    Mini DSP for a UMIK microphone, REW for the software.
    Then on value for the processing, one of the small MiniDSP boxes would do the trick.
