Mains - Cable Belden 83803 or FURUTECH FP-314AG?
Discussion in 'audio' started by alans1957, Mar 31, 2016.
  1. alans1957
    alans1957 pfm Member
    I intend to make up two new power cables for my amps and spotted these 2 cables are similarly priced, so there is my dilemma. I know the Belden is very good, but have no knowledge of the Furutech. I will be recycling my Toughplug and Wattgate IEC from my current homemade cables.
    Has anyone compared the above 2 cables?
  2. muzzer
    muzzer Numb Nut
    I have just read this on the Furutech website about 314AG
    :eek:
  3. whatsnext
    whatsnext Naimless
    Making two cables. Why not make one cable from each then you can tell us how different they are?
  4. alans1957
    I note a degree of sarcasm here sir! :) However I suppose I could advise if one channel sounded better than the other. :rolleyes:
  5. whatsnext
    whatsnext Naimless
    Do you? How do you do your noting? So you won't bother then?
  6. brian2957
    brian2957 pfm Member
  7. Barrymagrec
    Barrymagrec pfm Member
    I think you will get a wider soundstage for your hi fi and and it will turn your old standard format TV into a widescreen version.
  8. Andrew.B
    Andrew.B pfm Member
    Belden 83803 is a nightmare to work with without the correct tools and terminations as it's an installation type cable. I cringe seeing plugs attached to it.
    19364 is a suitable overkill alternative.
  9. alans1957
    LOL
  10. alans1957
  11. alans1957
    Have already made a cable for my Airlink transformer using 83803, found it not too bad providing you take the time to cut and dress the cores to the correct lengths. I agree that even with a toughplug you have no way of actually clamping the cable, but providing you secure the cores tightly and are not in the habit of regularly unplugging from the mains, I don't see it as a problem.
  12. Pete MB&D
  13. GJO
    GJO pfm Member
