Monitor recommendations; max 24” - HDMI/Displayport
Discussion in 'off topic' started by hifilover1979, May 26, 2019.
  1. hifilover1979
    hifilover1979 Bigger than you...
    Looking for recommendations on a flat screen monitor for a 2012 Mac Mini
    Max 24” ideally; needs to have HDMI and DisplayPort connections
    Looking for as best a picture quality I can get; ideally £150-£200; but will look at options over that too, just nothing daft ;)
    Cheers
  2. fatmarley
    fatmarley Registered User
    After lots of searching I chose the Dell Ultrasharp U2415 because colours are supposed to be very accurate out of the box and because of the 16:10 screen.
    I've had it about 6 months now and i'm very pleased with it.
    hifilover1979 likes this.
  3. dweezil
    dweezil pfm Member
    Don't know anything about Macs but we use cheap HDTVs now. £150 to £200 although you might find 24" trickier, 32" seems to be a small standard .
  4. hifilover1979
    Thanks. That looks a good’un
  5. hifilover1979
    fatmarley likes this.
  6. davidsrsb
    davidsrsb pfm Member
    I have a 32" Viewsonic 2560x1440 and to be honest this resolution would be wasted on a 24", text would be too small
  7. hifilover1979
