[WTD] Naim Lavender interconnect 5 pin DIN to 2 RCA - 1 meter
Discussion in 'classifieds' started by wpm, Sep 3, 2019.
  1. wpm
    wpm pfm Member
    Hi,
    I am looking for a pre-loved Naim Lavender interconnect 5 pin DIN to 2 RCA
    Only NAIM original make please
    Length = min 1 meter
    Please let me know
    Best regards
    wpm
  2. wpm
    wpm pfm Member
    Hi
    Am Still looking..
  3. RoryL
    RoryL Active Member
    Wasn't aware Naim ever made the lavender interconnect in 5 pin to 2 pin .. but perhaps you know differently.
  4. wpm
    wpm pfm Member
    Hi Rory
    I understand it was Lavender gray
    Please correct me
    Regards
  5. RoryL
    RoryL Active Member
    Quite right, in 5 pin to 5 pin configuration as supplied with most standard source components. Just not sure it was ever available as 5 - 2 pin - but am ready to be corrected. (connected!). At higher cost, and better performance, the HiLine is certainly available in a range of configurations.
  6. RoryL
    RoryL Active Member
    If you struggle to find an original, and cost is an issue, Chord Co Chrysalis is not a million miles away. From thence onwards and upwards .. you pays your money ...
    wpm likes this.
  7. hamjam
    hamjam pfm Member
    I don't think they ever did. Back in the day I had Andy ALW Audio make me one up. I still have it. Flashback cables were the other go to for non standard Naim interconnects.
  8. RoryL
    RoryL Active Member
    How will it be used?
  9. wpm
    wpm pfm Member
    To connect a non Naim CD Player or phono stage to Naim SN2 DIN i/p
  10. mjw
    mjw pfm Member
  11. RoryL
    RoryL Active Member
    If the player is appropriate quality to feed SN2 - I'd recommend HiLine, even if it means waiting. The investment will repay you handsomely. For something cheap and cheerful, non-naim items abound from a tenner upwards.
  12. Mickdale
    Mickdale Active Member
    There’s a 1.5m long hi-line one on the bay fir £100 (naim and much better than lavender)
    RoryL likes this.
  13. wpm
    wpm pfm Member
    still looking for lavender / gray NAIM 2 RCA to 5 pin DIN = 1 meter
    regards
