Onix OA21 rotary selector switch
Discussion in 'd.i.y.' started by misterc6, Aug 6, 2019.
  1. misterc6
    misterc6 Wasted and wounded, it ain’t what the moon did
    My newly acquired OA21 suffers from an intermittent loss of signal on one channel of the 'Tuner' input. As this comes and goes with the lightest touch on the selector knob I'm guessing the switch itself needs replacing. Does anyone know where I can get one of these?
    [​IMG]IMG_0634 by MALCOLM CONNAH, on Flickr
  2. booja30
    booja30 pfm Member
    I believe it is (or can be replaced with) a Lorlin rotary switch.
    When buying you need to select:
    * number of switch positions
    * number of poles (simultaneous connections for each position)
    * angle of throw (rotation between consecutive positions)
    It's a little confusing but you may wind up with one that has more poles than you need. I believe that the number of positions x number of pole is 12 for all of this type. So if for example you have 4 inputs to select, you order a 4 position/3 pole model and ignore one of the poles.
    I used this one for a recent project.
    misterc6 likes this.
  3. misterc6
    Thanks, that’s fine. I don’t understand why my search for a 3 pole 4 position rotary switch on Farnell didn’t find this but I’ll add it my next order.
  4. Pete MB&D
    Looks like a 2 pole 6 way to me, they have an adjustable stop so you can select the number of ways.
    Have you tried in clipping the back and cleaning the contacts?
    Pete
  5. davidsrsb
    davidsrsb pfm Member
    How many selections does it have, the switch does look more like a 3 pole 4 way, with one set unused?
    The chances of getting an old switch apart without any plastic bits breaking are remote
  6. misterc6
    Yes, that's correct and why I plan to replace it with new.
  7. snowman_al
    snowman_al pfm Member
    In which case could you not swap (or parallel) the connections to the unused section? Until you get a replacement.
    davidsrsb likes this.
  8. Tony L
    Tony L Administrator
    Have you tried squirting some Deoxit D5 into the hole in the middle and turning the switch to each end of its travel a good few times?
    PS It is ridiculously expensive, but it really does work on pots and switches!
  9. misterc6
    I tried a squirt of Maplin's contact cleaner but that didn't help. Taking into account the age of the amplifier (>30 years) together with the facts that I hope to be around for a good few years to use it, that it arrived with me too late for Adam's final renovation project, and that the replacement part will cost me around £3 I will be taking that route!
    Dowser and booja30 like this.
