Optical Toslink Cable suggestion
Discussion in 'audio' started by gerlando, May 20, 2019.
  1. gerlando
    gerlando pfm Member
    Hello there,
    which optical toslink cable do you suggest between my Yamaha WXC-50 digital streamer and my DAC?
    I'm thinking about Audioquest Pearl/Forest or Qed Performance.
    Other suggestions?
    Many thanks.
    Mauro
  2. narabdela
    narabdela who?
    Dare I suggest something cheaper, or might that spawn another cable thread?
  3. gerlando
    gerlando pfm Member
    Audioquest Forest is currently £24 on Amazon...
  4. mikemusic
    mikemusic pfm Member
    My friendly dealer Tony who has sold me enough Coherent mains cables and interconnects told me a cheapo Toslink would be fine feeding into my TAD Pre/CD/DAC
    Sounds good to me.
    Comparing to a Mark Grant Coax from Pi to TAD (using either) the Toslink sounded better.
    On Ebay for about a quid
    narabdela likes this.
  5. gerlando
    gerlando pfm Member
    So which Toslink did you use?
  6. mikemusic
  7. gerlando
    gerlando pfm Member
  8. mikemusic
    Happy to help.
    Surprised a cheap Toslink could do so well.
    Worth a punt for the money
  9. foxwelljsly
    foxwelljsly Keep Music Vile
    I'm using all 3 toslink inputs on my Linn Akurate Kontrol and 'something cheap from e bay' is plugged into all of them and they all sound fine. If you want to pay more, go for it.
    booja30 likes this.
  10. gerlando
    gerlando pfm Member
    Just ordered it on ebay.
  11. Whatsisnaim
    Whatsisnaim pfm Member
    Toslink is quite a poor standard, and one issue that is common is a poor fit between plug and socket, so that they can work loose. If the cable is very stiff, that sometimes makes this problem worse. So I would choose a cable that feels like it has a secure fit at both ends, and buy from a supplier who will allow you to return it for a refund if it doesn't fit well.
    hifinutt likes this.
  12. mikemusic
    The fit on mine is much too tight. Cable thin and floppy
    Hopefully the next one will be an easier fit
  13. Fire99
    Fire99 pfm Member
    I use Wireworld’s Supernova 7 which uses Borosilicate glass fiber optic conductors and have been very impressed with its performance.
  14. narabdela
    narabdela who?
    That's a lot to pay just for a good fit. :eek:
    booja30 likes this.
  15. gerlando
    gerlando pfm Member
    "Oh baby baby it's a wire world..." :eek:
  16. Andrew C!
    Andrew C! Been around a while....
    I have a couple of Chord Opichord 1metre longcables available: £20 each, posted (uk);)
  17. simon g
    simon g Grumpy Old Man
  18. Fire99
    Fire99 pfm Member
    I agree and I wouldn't pay for the fit of a cable either . I was just impressed with the sound having first started off with an optical cable from Cambridge Audio and then was given the Wireworld to audition a year later, I was sold after hearing it. I just lucked out that it fits securely.:)
  19. Moggi1964
    Moggi1964 Active Member
  20. vinylslug
    vinylslug Rebuilding my Vinyl collection.
    I recently used a QED Performance Graphite Toslink and found it difficult to tell any difference between it and a Chord Clearway Coaxial in A/B comparison. I preferred living with the Chord ultimately, but it's 2 1/2 times the price. The QED is impressive.
