Rega P3 Motor not working
Discussion in 'd.i.y.' started by Keith Smith, Oct 12, 2016.
  1. Keith Smith
    Keith Smith Getting older every day.
  2. hp1
    hp1 pfm Member
    use a meter to test the switch, caps should be ok and the windings measure approx 2.45k ohms each and can be measured in circuit= grey/blue and grey/red the other.
  3. YNWOAN
    YNWOAN 100% Analogue
    I would be very surprised if it is the motor that is at fault. The motor pulley is glued is place with superglue - are you sure it hasn't become free and the motor shaft is just spinning within it?
  4. davidsrsb
    davidsrsb pfm Member
    Also does the shaft turn freely?
  5. Keith Smith
    The pulley was loose ( now removed ) but still no power and the motor spindle, seems to be solid ...
  6. John_73
    John_73 pfm Member
    Remove & check for bad solder joints on the pcb.
  7. davidsrsb
    Do you mean the shaft is seized?
  8. Keith Smith
    Ok, please be gentle as I have limited knowledge here and seem to be learning quickly
    The switch seems to be fine, checked with metre
    Soldering looks ok ?
    http://i1227.photobucket.com/albums/ee438/keithsmith1/IMG_1081_zpswttuglca.jpg
    The shaft on the motor, will not rotate by hand at all ..
    I have a meter and have attempted the readings blue / grey and red / grey but with no real positive results
    What's my next course of action ?
  9. Pete MB&D
    A drop of thin oil in the bearings and leave it somewhere warm might loosen things up.
    Pete
  10. Keith Smith
  11. Pete MB&D
    They are film caps they don't often go wrong, the best test is to see if the motor runs.
    Pete
  12. Keith Smith
    Is there a quick way to test it ?
  13. Michael J
    Michael J pfm Member
  14. Keith Smith
    Thanks can I bypass the pcb, motor red / grey and blue / grey in to chocolate block to mains ? Or do I need to reassemble ...
    Sorry I understand the principles just this is all a bit new and would rather be safe lol
    Thanks for the help,
  15. 337alant
    337alant Negatively Biased
    Here is the circuit diag for those motors normally they just need a 0.2uf cap and a 6.8K resistor if you are on UK 50hz mains
    http://www.farnell.com/datasheets/526545.pdf
    Where is your resistor BTW?, this is only a 110V motor.
    Alan
  16. Michael J
    You have freed up the motor? Put it back together. I doubt that the motor is designed for unadulderated 240V AC, it'll probably try to reach orbit and rapidly burn out without the control circuitry. The choccy block is just quicker, easier, and in many cases better, than soldering.
  17. Pete MB&D
    Put it back together to be on the safe side.
    Pete
  18. sq225917
    sq225917 situation engineer
    Your motor was stuck,glue the pulley back on and put it back as was. The question is what caused the motor to seize?
  19. Keith Smith
  20. davidsrsb
    Using WD-40 as lubricant?
    It is too volatile, use something like sewing machine oil to lubricate the motor
