[WTD] Rush 'Clockwork Angels' on vinyl
Discussion in 'music classifieds' started by madscientist, Apr 6, 2020.
  1. madscientist
    madscientist pfm Member
    Does anyone have a copy of 'Clockwork Angels' by Rush on vinyl they would sell? PM please
  2. stereosteve
    stereosteve Member
    There’s a few on eBay, but they are a bit pricey.
  3. bodicus
    bodicus pfm Member
    https://store.roadrunnerrecords.com/clockwork-angels-lp.html
    It is not showing as out of stock, so you might get lucky. From the US probably which will mean two things. Both of them unpleasant, so you may not be so lucky!
    1) Postage may be scandalous
    2) Pressed by Rainbo
    I have two copies. One still sealed. The copy I opened required a replacement disc 1, as it was so badly pressed off-centre. Disc 2 is off-centre too a bit so I just drilled it out. Life`s too short to worry about label damage. I assume the sealed copy is a similar bag of the proverbial. Almost everything I have that was pressed by Rainbo was seriously faulty for one reason of another. If it`s absolutely necessary to have a copy to play I`d go for the EU pressing. I don`t have one but I`d say the Pallas pressing is excellent to stellar - they usually are (Neil Young lp`s notwithstanding :)). It`s not much better than the cd, so don`t expect miracles either! (Played on an Oracle Delphi btw).
    https://www.discogs.com/sell/release/4835484?ev=rb
    Mad money for sure, but they seem to be thin on the ground recently.
    Hope you get a decent copy for decent money.
    Cheers,
    Dave.
  4. Vinny
    Vinny pfm Member
  5. madscientist
    Thanks for the heads up guys. I have ordered a copy through Metal Scrap records (EU pressing) and will see how this goes. Much better than the >£150 prices on Ebay.
    bodicus likes this.
  6. bodicus
    bodicus pfm Member
  7. moomaloo
    moomaloo pfm Member
    Did it arrive?
  8. madscientist
    Not yet it is still in transit apparently...damn you covid19.
  9. Paul Mc
    Paul Mc pfm Member
    I want one.
  10. madscientist
    So do I, mine seems to have vanished into the ether
  11. madscientist
    Good news is the album has finally landed after 6 weeks. The bad news is both records are badly warped (pallas pressing). They play ok but look awful as they spin around on the turntable. I will have to keep it as I will.not be sending it back to the Ukraine...
  12. bodicus
    bodicus pfm Member
    I use two sheets of toughened glass approx 14" x 14". Ton of books on top. Few days close to the radiator or not too hell yeah heat source usually does the trick. I wet vac first though.
  13. madscientist
    Thanks for the tip I will give it a go.
