USB cable makes a difference shock!
Discussion in 'trade discussion' started by Purité Audio, Feb 6, 2019.
  1. Purité Audio
  2. Cereal Killer
    Cereal Killer fourhundredandthirtytwo
    So differences are measurable and do exist. SHOCKING!!!!
  3. Purité Audio
    But inaudible.
    Keith
    joe9407 likes this.
  4. Cereal Killer
    Maybe out of the human hearing range, but what if the deleterious effect is affecting other kit at attached ends?
  5. Purité Audio
    It won’t.
    Keith
  6. Cereal Killer
    Explain how you know that...
  7. Purité Audio
    Because the differences are -140dB minimum .
    Keith
  8. Cereal Killer
    That's nothing to do with what i asked.
  9. Purité Audio
    You understand what -140dB means right?
    Keith
  10. Cereal Killer
    Yes absolutely, don't answer my question with a question.... i'll say it again incase you didn't see it: what if the deleterious effect is affecting other kit at attached ends?
  11. narabdela
    narabdela who?
    I think I sense some straws being clutched. Out of range of my hearing though.
  12. Cereal Killer
    No, no at all, my question has nothing to do with dB rating....
    The test result shows the D-A conversion shows measurable differences @-140db+
    My question is what are the differences causing in the D-D environment? this isn't remotely the same question.
  13. Cereal Killer
  14. Marky-Mark
    Marky-Mark pfm Member
    The only kit I can imagine in danger would be someone's credit card.
    nicetone and lazycat like this.
  15. awkwardbydesign
    Whenever I notice Marky-Mark has posted, I just have see what reasoned analysis he has provided this time.
    I just can't help myself. :D
  16. AndrewM
    AndrewM pfm Member
    This test shows that the difference in the cables is measurable but below the human hearing threshold. Can you show any test results to show that the difference is audibly affecting other attached kit? If not, yours is a rhetorical question only in the context of this test.
  17. Cereal Killer
    Thats exactly what I'm asking!!
  18. Millennium
    Millennium Active Member
    It's something like Radio 3 and 4 though, so, you know, psu is iffy (lol)
  19. thebiglebowski
    thebiglebowski pfm Member
    It has everything to do with dB
    If we assume that the output voltage of a DAC is 2V then the noise at -140dB is (at most)
    0.000000000000002 Volts
    or
    0.2 pV (that is pico which comes after milli, micro and nano)
    Do you think that would be audible (hint - anything below -60 dB is inaudible to the average person) or could possibly have any effect elsewhere?
    If you want to use a digital argument (which really doesn't apply in that test but we'll play along for shits and giggles)
    USB 1.0 uses a signal differential of roughly 3v to represent a 1/0 therefore using a 3v reference -140dB would equal.....
    0.000000000000003 Volts
    or
    0.3 pV
    Even at the highest bandwidth and specific signalling USB 2.0 looks for a differential voltage of 400mV that is 0.4 Volts
    Do you think that either 0.000000003 or 0.0000000004 mV could cause any spurious effects?
    nicetone likes this.
  20. Cereal Killer
    Thanks for the detailed maths on db ratio. I was aking what is happening in the digital to digital domain not in the analog result.
